This command configures port bouncing on a port, which temporarily disables and re-enables a network port in order to reinitiate a DHCP request.
| on | Specifies turning ON port bounce. |
| off | Specifies turning OFF port bounce (Default). |
OFF.
The following conditions must be met for this command to work:
The following example turns on port bouncing on a switch:
# configure radius port bounce on
This command was first available in ExtremeXOS 32.5.
